Hi NXP,
What I want to know about this strategy is whether FS0B automatically becomes high after meeting the recovery conditions, or does it need to be released again via software ?
Thank you in advance
When the fail-safe outputs FS0B is asserted low by the device due to a fault, the exit
conditions must be validated before allowing these pins to be released.
These conditions are:
Do I also need to release FS0B again via software after FCCU recovered during the recovery window?
For the SBC side to release FS0B:
Firstly fault should be removed, then read the related registers to make sure LBIST_OK = ABIST1_OK = ABIST2_OK = 1 and Fault error counter=0 then fill the RELEASE_FS0B registers to release FS0B.
