In FS26xx, Is BATSENSE used for any other purpose than AMUX?
已解决! 转到解答。
The Fail-safe machine is powered by VSUP, with a redundant supply connectionavailable through VSENSE.
This pin is for Battery sense terminal and Connection mandatory.
What will happen if this pin is open? or if it is shorted to GND?
The safety function will be effected.
It is going to assert the FS0b pin?
