How can I restart system from linux in case no watchdog is on. I mean - when I send shutdown -r now I want to real system restart. Is there some special register or special sequence of registers writing for restart CPU like hard reset by power switch on?
You should use the POR signal from CPLD registers. Something similar with this [1]. These details can be found in the board/CPLD manual.
Marius
