how to simulated with ADS
2,669 次查看
alleniub
I have added two design-kits downloaded from the official website to ADS, but ADS still shows errors
AFT09MS031N RF High-Power Model ADS Product Model Design Kit
RF High Power Model Kit 2022 - model definition required to run all RF High Power ADS Design Kits.
https://imgur.com/a/MoEt12l
2,638 次查看
ErikaC
Thank you
This appears to be customer not installing RF High power Model Kit before using single product model.
https://www.nxp.com/products/rf/rf-high-power-models/models-for-ads-keysight-advanced-design-system:...
Our models are two part :
Both parts are required to simulate device
Please, refer to:
https://www.nxp.com/docs/en/company-information/OVERVIEW_MDL_ADS_DESIGN_KIT.pdf
If this is not the case, please try with an earlier version of ADS 2019 or 2020.
5 回复数
2,639 次查看
ErikaC
Thank you
Please, refer to:
2,541 次查看
Wangk
Do we have
RF High Power Model Kit 2023?
2,645 次查看
alleniub
I try two different design-kits AFT27S010N AFT09MS031N.
It shows same Error.
2,647 次查看
alleniub
Warning detected by hpeesofsim during netlist parsing.
Model `FSL_AFT27S010N_FET2.FET2M1' (defined in file 'D:/ADS/helmholtz_wrk/AFT27S010N_Level2_Rev0_DK//circuit/models/fsl_AFT27S010N_pkg_netlists.net' around line 27): `FSLRFPK_FET2' is an undefined primitive device.
Warning detected by hpeesofsim during netlist flattening.
Resistor `FET2FSL1.R1' is shorted.
Error detected by hpeesofsim during netlist flattening.
`FSL_AFT27S010N_FET2.FSL1' is an instance of an undefined model `FET2M1'.
2,648 次查看
ErikaC
I can not see the image, can you paste the image in your post or copy and paste the error, please?
Regards.
