Wireless Charging distance
berniecheah
I have a customer planning to use our wireless charging solution. But notice most of the spec is unable to achieve the receiving distance of 15mm. Most of them is around 7-10mm.
Is there any solution that is able to achieve 15mm of receiving distance? In case I might have missed out some..
Or is there any way they are able to achieve this (ie. modifying software or hardware?)
Does not require automotive grade.
guoweisun
