What is a 'reach-through avalanche photodiode'?
xiaoye
The alternator diodes are a component of the rectifier assembly, which transforms the alternator's alternating current output to direct current. The charging output of the alternator passes through six diodes in the rectifier assembly before reaching the battery and electrical system.
hope someone can help me. many thanks
bobpaddock
Senior Contributor III
Photodiodes, from the subject line, and Alternator diodes from the message text, have nothing to do with each other than they both contain the word 'Diode'.
What problem are you trying to solve?
