TJA1046/TJA1048 CAN Transceiver
adnan
Can I use the dual channel TJA1046/TJA1048 CAN transceiver as shown in the attached picture below? I would like to mux the TX1/RX1 and TX2/RX2 together connect them to a single TX/RX interface on the MCU. The individual CAN BUS interface can be enabled and disabled using the STANDBY pins.
Thank you
guoweisun
Yes,you can do that!
