Can TX1, TX2 and TX3 be turned on at the same time without exceeding the maximum power range?
Solved! Go to Solution.
I had consultations with radar expert and there is no issue to turning them on at the same time.
Should not be a problem.
One problem arising, depending on duty cycle, could be heating of the device, so proper cooling needs to be in place.
But lets say with a common duty cycle of 50% and all three TXs on, I don't see a problem.
Peter
Peter
I do not know about any TEF8012 limitations.
But let me chcek with TEF application engineer next week. (due to holidays)
Peter
