TEF8102 TX1 TX2 TX3 turn on at same time
811 次查看
longfeiwang
Can TX1, TX2 and TX3 be turned on at the same time without exceeding the maximum power range?
793 次查看
petervlna
I had consultations with radar expert and there is no issue to turning them on at the same time.
Should not be a problem.
One problem arising, depending on duty cycle, could be heating of the device, so proper cooling needs to be in place.
But lets say with a common duty cycle of 50% and all three TXs on, I don't see a problem.
Peter
794 次查看
petervlna
Peter
796 次查看
petervlna
I do not know about any TEF8012 limitations.
But let me chcek with TEF application engineer next week. (due to holidays)
Peter
