Regarding to CLRC66303HNE
jackhsu
Good day.
May i know the #CLRC66303HNE is able to be programmed by third party?
If yes, could you help to provide the programming guide for detail?
Thank you.
Jack
jackhsu
Hi Daniel,
Thanks for your reply.
We are third party manufacturer.
is it possible to release the programming guide if we would like to support the programming algo on our programmer?
Thank you.
danielchen
Hi @jackhsu
CLRC663 is an NFC frontend device can be used with your required MCU/HOST.  We have evaluation kit which is having LPC1769 as host.
We provide reader library with examples to expedite devaluation of requirement.
Regarding the programming guide for LPC and CLRC663, please refer to AN11022
danielchen
Hi Jack
CLRC663 can be programmed with MCUXpresso IDE ( CMSIS-DAP, PEMicro, Segger J-link).
If you use third-party programmer, please make sure the base address is 0x203000
