Hi Team,
Am using raspberry pi board , interface with RTC , setting the hardware clock using "hwclock --set" command , reading the clock using hwclock -r command, initially reading properly as a set time but after some time changing to default time values..
Thanks in advance,
Nv.
Hello Naveen,
What RTC device are you using? I can help you with its configuration. Can you share your schematic?
David
Hi David,
We are using rtc-pcf8563 device and driver registered successfully ,
Initially clock , date setting and reading properly ,
after one day time changed to one hour delay , There is kernel logs for
debug. Please can you help me.
Please check once attachment.
Naveen Kumar,
Hi Naveen,
This is nxp community. So I think you should ask this question in raspberry community (for better support). BTW you can also get the assistance here if you will elaborate your question (like which RTC module are you using and if it is on the I2C so you can check the i2c communication through i2c utility) in a precise way.
Vinod
