Could you tell me the connection of the each GND pins (GND and PGND)?
PTN3356 has two GND pins GND and PGND.
I confirm its reference schematics in datasheet and application note, and they are connected to same ground.
Can I connect their Pins to same ground?
If I should separate them, could you tell me the suggested connection?
M.Kiniwa
Solved! Go to Solution.
Hi Kiniwa-san,
Hi Kiniwa-san,
