Hello! Where I can find example project for PNEV7462 board (with PN7462 MCU), to work with TDA8026?
Hello, this is NXP's technical support. Thank you for using our products.
I have great news for you, sir, there is no need to use the TDA80x with PN7462. Please check this Application Note for the migration path to the PN7462. The evaluation board contains a contact interface.
