NXP MRF101AN-13MHZ product usage issues
Fault description: Frequency range 7-10.5MHz, output power 100-110W, RF output path L2, L4 self-made winding inductor high temperature discoloration and power amplifier IC burned.
Our current problem has not been solved, and we hope to get more in-depth support from you. thank you
I will support you on your ticket 00620038
