Hi Team,
I am planning to use protection IC NX20P0407 for CC lines in my application. We require the CC lines signal flow should be in both the direction (source and sink). Can you please let me know whether the CC lines of NX20P0407 are bi-directional or uni-directional?
Anand B
Solved! Go to Solution.
Hi Anand,
The NX20P0407 is a bidirectional SW .
Depending on VSYS and SBUEN, CC and SBU switch is controlled.
You can see the table of power states in datasheet and below.
Tomas
Hi Anand,
Tomas
Thank you Tomas
