I am trying to communicate with an MCP2515. The MOSI has to send 0x0C and 0x0F but is sending 0x00 before each command. This because it is pulled up all the time, The pull down does not seem te have any effect even a resistor 10k does not solve this. How can I achieve this?
Hello Ben,
Unfortunately, this is not possible by any SPI configuration, to do this you will have to switch pin functionality to GPIO between transfers. Please check the thread below that explains more of this.
MOSI stays high after data transfer
Felipe
