How to use CLRC663 to read the ICODE ILT-M?
MIMIwho
Hello!
There is a problem. Please help.
I cannot read the tag. How can I read the ICODE ILT-M tag?
When I use RC663 with the SW335613 library to read a ICODE ILT-M tag, it is always return wrong, the error code is collision or protocol error. But I only place one tag.
Then I try another example, Nfcrdlib_SimplifiedAPI_ISO in SW297857 example, it is return wrong, too.
Is there have another example using for test?
KellyLi
Hello @MIMIwho
This is a repeated issue, please refer to the reply of case number: 00510883. Here I'll close this case.
Have a nice day.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
