Hello.
According to the JN5169 datasheet, when the device reset is active, all the SPI-bus master pins are configured as inputs with their pull-up resistors active. The pins stay in this state until the SPI-bus master block is enabled.
Control of the SPI Master using functions of the integrated API is described in JN516x Integrated Peripherals API User Guide, Chapter 14 Serial Peripheral Interface (SPI) Master. Section 14.5 describes how to use the API functions to operate the SPI.
Eduardo.
Hello.
Eduardo.
