Hi, I have a question concerning compatibility between HTRC110 component and an EM Micoelectronic EM4205-EM4305 chip.
Could you let me know if the one can read the other ?
I currently us a RFID tag with a 40bit UID. The EM4205-EM4305 chip are in 32bit UID.
https://www.emmicroelectronic.com/sites/default/files/products/datasheets/4205-4305-DS-01.pdf
Thanks!
Hello @LagzHBX109
In terms of supported protocols, HIRC110 can read and write EM4205 through NFC interface. But EM4205 is not from NXP, so I can't give you any more advice. However, it is recommended that you use this combination (HTRC110+HITAG S) in your design. Here are some design documents that might be helpful to you and let me know in case of you need them.
Kelly
Technical Support
NXP Semiconductor
Hello @LagzHBX109
You're welcome.
Kelly
Technical Support
NXP Semiconductor
