Hi everyone,
Is there an emulator of MC1322x boards (network and sensor node) ? I need that because when I change the code I need everytime to check if my changes are ok so it becomes boring and in addition I think it's not practical for the boards to erase and update the flash many times. It can damage them...
Solved! Go to Solution.
Hadhoud,
there is no emulation available for this IC.
Typically emulation is only available when you have a generic cores(you can find an arm7 emulator) but not when there is specific components like the RF and accelerator.
br,
Mads
Hadhoud,
br,
Mads
