A1006 Authenticate IC
524件の閲覧回数
Dayanandkilledar
Hi All,
can anyone tell the sequence flow for the A1006 IC.
I was following the A1006 Secure Authenticator IC Product short data sheet
for example when can use the powerdown, wakeup, lockdevice, changeaddress, softreset and what is the sequence?
what is the minimum delay should i keep in between these API's.?
can anyone provide me the proper sequence flow of these API's.
513件の閲覧回数
Kan_Li
Hi @Dayanandkilledar ,
Actually this part is a none mass market product and all its documents are under NDA, we are not allowed to share the info here publicly , and such kind of products are usually supported by NXP FAE, is there any FAE following up with your project?
Kan
