P&E micro failed to open usb serial
819件の閲覧回数
bugs
I was trying to use CS10 to debug MQX virtual com exmaple, and CW10 found out the debugger firmware is too old, and need to upgrade, so I did the upgrade from 28.2 to 29.0, and After the upgrade, The Terminalwindow program failed to open UBS serial port.
How can I solve this issue?
ラベル(2)
タグ(2)
476件の閲覧回数
JimDon
Senior Contributor III
More information is required to help you.
What board are you using? Which port are you looking for?
Do you mean a com port from the OSBDM or something else?
