GetVcList description unclear
948 次查看
eshwarchandrapa
If a mifare implementation supports vc entries range 0-0x15 and if no virtual cards are created yet and i send GetVcList command with vc entry range 0 to 0x15, filter criteria MSB 0x7F and LSB 00, what should be the response of this API?
752 次查看
Jonathan_Iglesias
Dear Eshwar chandra Pavaganda, could you please confirm the IC you are using, to check the specific information for that device.
Looking forward to your reply.
Jonathan
