Undefined reference error using GDFLIB
1,040件の閲覧回数
rafael_barbosa
I am using the MBD toolbox 3.0.0 and the target micro-controller is MPC5744P.
I can generate code using GDFLIB blocks (thanks Reference to non-existent field 'info' using GFLIB block ), however I can't debug it (neither flash it in the micro) using S32 Design Studio.
I am using the block GDFLIB_FilterMA_FLT in Simulink.
After code generation and importing the project in S32 Design Studio, I am getting the following error when building project:
Can you support me with this problem?
Please see the example model attached.
paulvlase‌
mariuslucianandrei
923件の閲覧回数
constantinrazva
Hello rafael.barbosa@chassisbrakes.com ,
This issue is due to missing library from linker arguments. It is an older issue that was fixed in the more recent releases, but the workaround is simply: you right click on the project that you have imported into S32 Design Studio, go to C/C++ Build -> Settings -> Standard S32DS C Linker -> Libraries, and add the following (from the green + signs), as in the picture below:
":MPC574xP_AMMCLIB.a"   -- add this to Libraries
"{TOOLBOX_DIR}\mbdtbx_mpc574x\AMMCLIB_MPC574xP\lib\s32ds_ppc"   -- add this to Library search path
This should do the trick - let me know if you have further issues with it.
Kind regards,
Razvan.
4 返答(返信)
924件の閲覧回数
constantinrazva
Kind regards,
Razvan.
923件の閲覧回数
rafael_barbosa
Dear constantinrazvan.chivu‌,
Thank you very much for the support, it is working now.
Kind Regards, Rafael
923件の閲覧回数
constantinrazva
Glad to hear that rafael.barbosa@chassisbrakes.com !
Kind regards,
Razvan.
923件の閲覧回数
mariuslucianand
Hello rafael.barbosa@chassisbrakes.com‌,
For this question, constantinrazvan.chivu‌ can help you with that :smileyhappy:.
Thank you, Razvan!
Marius
