Reference to non-existent field 'info' using GFLIB block
rafael_barbosa
I am using the Simulink (MATLAB 2018B) with the Model Based Design Toolbox 3.0.0 for MPC5744P target.
I can't generate code due to the following error:
### Build procedure for model: 'ERROR_Example' aborted due to an error.
Failure in mbd_mpc574x_make_rtw: Reference to non-existent field 'info'.
Component:Simulink | Category:Block diagram error
Please see the example model attached.
Really simple example.
Can you support me why there is this error?
Regards, Rafael
paulvlase
Hi [email protected]‌,
I can reproduce your error on my side too. It seems to be an exception inside Simulink.
Because the error doesn't say too much about what it caused and I don't have access to the Simulink code to debug it, I can only give you right now a workaround to be able to build the model.
The workaround is to go to Configuration Parameters > Code Generation > Report and uncheck the Static code metrics option.
The static code metrics report is not generated anyway because Simulink fails to parse the compiler's C standard header files, like stdint.h.
I hope this helps you,
Paul
rafael_barbosa
I also tried to install the Model Based Design Toolbox 3.2.0 and the problem persists.
mariuslucianandrei‌
constantinrazvan.chivu‌
Can you support me with the blocking point?
Kind Regards, Rafael
mariuslucianand
paulvlase‌, can you comment on this?
Thank you,
Marius
rafael_barbosa
Do you have some updating on this topic?
It is quite urgent from my side.
paulvlase
Paul
Daniel_Popa
paulvlase‌,
If this is a Simulink issue, please make sure our colleagues at MathWorks are aware. (brianmckay)
rafael_barbosa
Hello Paul,
It worked fine.
This workaround is enough for me.
Thank you very much for the support!
