Hi Team,
I have implemented MBDT system to receive CAN signals from an external IVT sensor and read the signal using NXPS32K144 board and observe the same in Freemaster. But all the variables show zero in it. Please check the model i have uploaded and suggest for any corrections or settings change to be made.
Hi SorinlBancila,
Thank you for your response, i will try the same what you have mentioned.
At the first glance, the model seems to be ok. Can you please add another variable (apart from the ones used by the CAN blocks) to check if the model is properly running (like a variable incremented at every execution step)?
Below are a few suggestions that might solve your problem:
Sorin Bancila
