I am trying to run one of motor control toolbox example code on MPC5744P but when ever i hit the play button I get the following error.
No method 'getComponentBuildInfoPath' with matching signature found for class 'pntpil.MakefileBuilder'.
can you please tell me what is the issue here.
Ali
解決済! 解決策の投稿を見る。
Hi Daniel,
Thank you very much.. I am able to simulate. The problem is in serial communication.
Sundar
Thanks for the hotfix paulvlase. I was also facing the same "ProdEndianess" error as Ali and Sundar.
Also FYI, I also ran into the same error using the MPC5643L MBD Toolbox. I am running 2016b.
Hi Paul,
Thank you very much, I will try it and let you know.
Ali Meraj
I tried this 2017a
Can you post screenshots with "Code Generation" and "Hardware Implementation" (with "Device Details" expanded) sections from Configuration Parameters?
Matlab 2017a config settings
Hi Paul,
I extracted lecture 7 files again and tried to run the model as following:
and it throws the error straight away:
Ali
Hi Paul,
I am using 2014b
Ali
