Motor Control Class: Lecture 6 - Commutation
6,847件の閲覧回数
Daniel_Popa
In this sixth lecture of the motor control course we discuss about how motor phase commutation works and how can we build a commutation table to ease the software processing to compute the PWM sequence that controls the power inverter which turn the rotor.
Main topics:
    - How the rotor turns when voltage is applied;
    - How to define the commutation table;
    - How to control the power inverter switches;
    - How to identify the commutation sequence;
Objectives:
    - Understand the concept of 6-step commutation;
    - Design the commutation vector table;
    - Understand how to operate the power inverter;
    - Test your knowledge with a short quiz;
NOTE: Chinese viewers can watch the video on YOUKU using this link
注意:中国观众可以使用此链接观看YOUKU上的视频
Additional information:
    - pdf attached with slides shown in these videos;
3 返答(返信)
5,263件の閲覧回数
jimduanva
dumitru-daniel.popa
I have tried a few  different orders of Phase A/B/C and Hall 1/2/3. The result communication table had different pattern as yours; is that all right?
If it's true, what's the main reason to cause the pattern difference?
Jd
5,267件の閲覧回数
Daniel_Popa
Hi jimduanva‌,
It's true! So this is a very important step in making the BLDC motor working. In fact over last weekend i had to redue the procured for a another motor in order to make it run.
Initially, i thought to save some time and started to play with the CW and CCW tables manually hoping to find a quick setup to work. I managed to spin the motor but very oddly. At some point i've decided to repeat the procedure shown in this lecture and in less than 1h i had the motor running correctly and honestly the commutation tables were totally different than what i was trying to guess.
Here is a good application node that describes in details this procedure.
https://www.nxp.com/docs/en/application-note/AN4413.pdf
Hope this helps!
5,268件の閲覧回数
Daniel_Popa
To test your knowledge or to have a discussion starting point let us have this short quiz session:
Q1: What is the name of the PWM technique used in this lecture to control the power inverter MOSFETs?
Q2: What are the main benefits of this PWM technique?
Leave your comments below.
Thank you!
