FlexCAN functions for MBD (MPC57xx) does not works as intended
2,717 次查看
abhishek_kumar1
Hello
I am using MPC5744P DEVKIT (Link)with 144LQFP micro.
I want to use the CAN to send and receive message.
Step 1
I changed the jumper setting of the DEVKIT to use 12V Power supply.
Step 2
Used the flexCAN master example project but on the oscilloscope, both high and low pins stay recessive.
I also used VECTOR CAN Tool to see if messages are being sent on the bus but there is nothing. Not even Error Frames.
Step 3
I adapted the model (attached) where I used PIT to make sure messages are sent periodically. But still CAN high and Low are recessive.
Please provide your input.
Abhishek
2,469 次查看
constantinrazva
Hello abhishek.kumar@chassisbrakes.com‌,
Your example worked in my current setup:
Do other applications work on the board? I would try to flash a simple LED toggle example. If that works, could you share the jumper settings?
Kind regards,
Razvan
10 回复数
969 次查看
Even1
Hello:
    Has this problem been solved? I also encountered the same problem, there are no messages on the CAN bus, and the configuration is as follows:
Best Regards
2,469 次查看
ssuyakov
Hi guys.
I've just got same issue which was described. I tested the attached example and it was perfectly working on my DEVKIT-MPC5744P Board and I captured same data in CanAnalyzer3 like on screenshot. But when I changed Bit Rate to 500 Kbit/s, recompiled project and upload to board I saw that LED has been stopped blinking and there is no traffic on CAN bus. Is it bug in MBD or something wrong on hardware level? sshot-2019-07-01-[10-07-58].jpg
2,469 次查看
constantinrazva
Hello ssuyakov@tae.com‌,
Could you share the generated code with us? And could you make sure you double-check the baud rate you've set in the USB-2-CAN application?
Kind regards,
Razvan.
2,469 次查看
abhishek_kumar1
Dear Sergey
Is it possible that you did not change the BaudRate at Canalyzer 3 side.This is one reason to have an error.
2,469 次查看
abhishek_kumar1
Dear constantinrazvan.chivu
It has been solved. It works, and I don't know why it works. I tried the same code again.
2,469 次查看
constantinrazva
I checked the settings you provided, and everything was ok, and also the model worked. I'm glad it worked on your side in the end.
Kind regards,
Razvan.
2,469 次查看
Daniel_Popa
Hi Abhishek,
Do you have 120R terminator ?
2,469 次查看
abhishek_kumar1
Dear dumitru-daniel.popa‌ and  mariuslucianandrei
We are using 120 ohm termination over CANH and CANL.
Also, 120 ohm at the other transceiver which is VECTOR CAN USB Interface.
I have tried with 2 different DEVKITS, just to be sure.
Do we need any new patch?
Best Regards
Abhishek
2,470 次查看
constantinrazva
Kind regards,
Razvan
2,469 次查看
abhishek_kumar1
The LED example works well.
Jumper Settings
J13 -> 1-2
J31 -> Not connected
J38 -> 1-2
J22 -> 2-3
J26 -> 1-2
J20 -> 1-2
J28 -> 1-2
J24 -> 1-2
J04 -> 2-3
J40 -> 2-3
J32 -> 1-2
J19 -> 1-2
Abhishek
