Dear engineer:
I discover that even the SDK example project can't run on RevB board. Is it becanse of the clock configuration?
Could you please specify what can't run means? Is the code stuck somewhere waiting for some condition?
Could you elaborate closer?
best regards,
Peter
This looks like your SW is branching somewhere in memory and for this location you dont have source code.
Debug code step by step, to see where it fails. (and check if you have source available for such address)
Peter
