MPC5777C Stack overflow exception
1,221 次查看
20Sidar04
Dear Mr./ Mrs.
When I checked e200z7 core document, I couldn't find exception for stackover flow. Is not available stackoverflow exception for MPC5777C?
Best Regards.
4 回复数
1,201 次查看
lukaszadrapa
one option is to follow section "60.4 Using Debug Resources for Stack Limit Checking" in reference manual for MPC5744P:
https://www.nxp.com/webapp/Download?colCode=MPC5744PRM
This is not mentioned in RM for MPC5777C but it's still applicable.
You can also take a look at this thread for some code:
https://community.nxp.com/t5/MPC5xxx/MPC5744P-how-to-use-the-debug-registers-to-realize-the-quot/m-p...
Next option is to use Memory Protection Unit when you can configure small area just below the stack as no writeable.
Lukas
1,196 次查看
20Sidar04
Dear Lukasz,
I cause stackover flow by calling recursive function in main source. But when I put breakpoint in IVOR13_Exception_Handler (IVOR13 - Data TLB Error Interrupt)  , it don't stop. I set  MSR. I set LED pin to test IVOR13. But not works for during debug mode also standalone mode. I wonder reason.
Best Regards.
标记 (1)
1,180 次查看
lukaszadrapa
How did you configured the MMU and where is your stack?
Lukas
1,134 次查看
20Sidar04
I used this source code for stack monitoring in main.c;
void config_SRAM(void){
PPCASM("e_lis %r4, 0x0000");
PPCASM("e_or2i %r4, 0x0000");
PPCASM("mtspr 563, %r4");
PPCASM("e_lis %r4, _stack_end@h");
PPCASM("e_lis %r4,_stack_end@l");
PPCASM("mtspr 316, %r4");
My function generate for stack overflow;
void generate_stack_overflow(int a) {
if (a== 0)
{return;}
a = 6;
generate_stack_overflow(a);
PPCASM("e_lis %r4, __SP_INIT@h");
PPCASM("e_or2i %r4, __SP_INIT@l");
PPCASM("mtspr 317, %r4");
