Customer has below queries. Pls help.
Amit Gombi.
Regarding delay I am not sure. Datasheet does not specify it. Are you calculating round trip delay or which parameter?
Unused pins are recommended to be put in this configuration: Output buffer disabled, Input buffer disabled, Weak Pull Down enabled. So it may be left floating.
