MPC5606s output clock generation
1,347 次查看
mhogun
Fresh Out Contributor
Hi all,
I am using below lines to generate the output clock in mpc5606s
CGM.OCDSSC.B.SELCTL = 0; /* MPC56xxP/S: Output clock select 16 MHz int RC osc */
CGM.OCDSSC.B.SELDIV = 0;
CGM.OCEN.B.EN = 1;  /* Output Clock enabled (to go to pin) */
SIU.PCR[103].R = 0x0E00;
But not able to get the 16MHz output.kindly help me
标签 (1)
1 回复
1,272 次查看
PetrS
The setting is correct, I was able to measure 16MHz on PH4 pin (PJ10.9 on MPC5606S EVB rev.C).
Be sure you are on right pin on the board.
BR, Petr
