How to flash a elf(generated outside S32DS) on the MPC5748G Devkit over USB ?
2,836件の閲覧回数
kishore_kumar_d
mpc5748g dev kit‌
I was successful in flashing this elf using the lauterbach + JTAG .
I am quite new to this Open SDA USB and seem to doing it wrong. I would like to know the procedure to flash a elf file over usb.
My tools are
Hardware
  1. MPC5748G DEVKIT powered by 12V Supply
  2. USB to Micro-B connector
Software
  1. S32 Design Studio v2017.R1
With this above setup i would like to know what procedure or what tools i would need in order to flash the elf on the development kit ?
P.S : I have already tried the flash configuration in S32 DS with the Target and core selected but somehow the flash doesnt go through and just hangs in between.
タグ(1)
3 返答(返信)
2,111件の閲覧回数
martin_kovar
Some time ago, I created document, which seems to be the right one for your requirement. Please see the link below and eventually let me know, if it helps you.
https://community.nxp.com/docs/DOC-332252
Martin
2,111件の閲覧回数
sk4
Hi Martin,
This is a very useful document for flashing the binary to MPC target. This mainly uses S32DS for all the options listed.
Is this flashing of binary can be done without S32DS? I have binary (.elf file) generated for a project using S32DS.
Thanks in advance.
2,111件の閲覧回数
jfrey
I wrote a short Python wrapper on the flash tool. I haven't tried it in a while. But it should work.
GitHub - jed-frey/opensda_flasher
If not open an Issue.
