How to flash S32 project for MPC564xL using Rappid bootloader?
1,039 次查看
deepak313
I created a project for MPC5643L in S32 design studio v1.2 and built and created a .srec file.
I do not want to use JTAG to flash.
Using Rappid bootloader utility, I can flash this .srec using serial port, but the code does not seem to run.
(I have another .mot file that I can flash using serial port and Rappid and it runs, so I am sure that the hardware and Rappid connection/configuration are okay).
I believe the .srec file may be missing some information.
How can I configure S32 options to generate a .srec to be able to flash using Rappid bootloader?
824 次查看
deepak313
Problem solved:
1. Make sure Build Configuration uses 56xx_flash.ld in the Linker settings
2. After flashing the .srec using Rappid bootloader, switch FAB to 0 and then reset, the code will run.
Same for flashing using JTAG, after disconnecting JTAG switch FAB to 0 and reset or power cycle.
