I installed the latest (v3.1) MCUXpresso Secure Provisioning Tool on a PC running on Windows 11 Pro Insider Preview (OS build - 22509.1011). The tool installed successfully but I can't use it afterwards.
I keeps on crashing with the following message:
Any help would be much appreciated. Thank in advance.
Solved! Go to Solution.
BTW, there was issue on Windows with some combination of locale settings. You can give it a chance on Windows 11 if you switch to English US region. But take it as a blind try.
Libor
Share my experience.
Change to support Unicode UTF-8 on Win 11, then can run it.
Jeff,
SEC tool v4 is already available. Is your feedback related to v3.1 or v4?
If this is problem in v4, can you be more specific, what exactly means "Change to support Unicode UTF-8"?
Thank you for the feedback.
Hi Marek,
Thanks for inform have SEC new version v4. I downloaded and test SEC v4. Also had unicode decoder error message.
Hi Pedro and kanimozhi_t,
Thank you for your inputs. We're sorry for inconvenience with problem with region settings, this problem can be reproduced also on Win10 and will be fixed in v4. Thank you for providing details how to reproduce it
Libor
Thank you, this trick works
Hi kanimozhi_t,
SEC tool was not tested on Windows 11 yet, so currently we do not have any information, whether it will work. Supported operating systems are listed in the Release notes.
About un-installation: the default uninstaller does not touch the data, created by the tool (e.g. workspaces) and also preferences. The preferences are located in <user home>\.nxp\secure_provisioning_v<version>\. The preferences are backward compatible, so for example SEC Tool v3 can load preferences from SEC Tool v2, if preferences for v3 does not exist yet.
Hope this helps,
On windows 10 it doesn't works too. It closes suddently.
Hi kanimozhi_t,
could you please let us know, what exactly configuration did not work? We'd like to ensure the configuration will work in next version.
Thank you in advance
Basically we earlier used,
And the tool didn't work. So I changed as follows,
Now the tool is working as intended and it would be nicer to have the India region (or UK for that matter) supported.
