I cannot see the signed value on my Global Variables view while debugging (variables defined as int16_t), just their unsigned value. In the Expressions view it works as expected but not in the Global Variables view. Should I wait for a fix in the MCUxpresso next release or I'm doing something wrong?
regards,
gaston
Solved! Go to Solution.
Hi gaston,
now I see what you mean, and I can reproduce it with the P&E connection. I'll pass this to the engineering team.
thanks for reporting!
Erich
Hi Erich,
Here's the screenshot while I'm debugging
However if I suspend the execution I see the signed variables as expected.
regards,
gaston
Hi gaston,
Erich
Maybe could you post a screenshot?
it works that way for me:
See that menu where you can specify the number format.
I hope this helps,
Erich
