my projects ok,
while edit text source code...the pc cause error memory and restart.
I oped project ok, "Virtual_com.c" text clear.
question: Is there a copy of the source texts?
if there is no copy, this source has been lost.
file attached.
thanks,
Carlos.
解決済! 解決策の投稿を見る。
Hi ZhangJennie ,
problems solved,
Avira Antvirus, it cause problems,
now use other antvirus not have problems with re- start pc.
thanks.
Carlos.
Hi ZhangJennie ,
problems solved,
thanks.
Carlos.
Good to know it.
Thanks for the sharing.
Jennie Zhang
Hello Carlos,
File virtual_com.c is part of SDK source file for emulating a USB port as RS232 port.
Its content is not exactly same based on different SDK version and target.
What's your SDK version? and what board is it for?
To avoid any misunderstanding, please also let me know this file path on your side.
Jennie Zhang
Hi Jennie,
Hello, my sdk is the (SDK_2.2).
my pc had memory problems when (compile) the code gave screen (blue).
I had put several new functions to the file.
I tried to restore local history, but it was not possible.
and, I had to do everything again in Virtua_com.c,
now I'm going to make copies of the projects for safety(file.bak).
thanks,
Carlos.
ok. please let us know if you need help.
Jennie Zhang
