Can I use FTDI FT2232 to debug LPC 1758?
1,071 次查看
rasodm
I'm using dLAN Green PHY eval II board. In the data sheet of that evaluation has mentioned that the LPC 1758 which is built-in can be debugged via UART0. I'm using MCUXpresso IDE.
FTDI data sheet
https://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT2232H.pdf
DLAN Green PHY data sheet
https://www.devolo.com/fileadmin/Web-Content/DE/products/bs/green-phy-eval-board-II/pictures/de/devo...
#ftdi#jtag debug#mcuxpresso tools
1,020 次查看
converse
Senior Contributor V
The MCUXpresso User manual states that the supported debug probes are:
- Native Linkserver (including CMSIS-DAP)
- Segger J-Link
- P&E Micro
so, I guess the answer to your question is no.
You can by an LPC-Link2, which is much faster than FTDI, for about $20. Its worth it.
