I've created a Pin/DDR configuration for a i.MX 8M Plus with "Config Tools for i.MX Version 11.0".
The generated "pin_mux.h" file includes the file "board.h".
Where is this file located ?
Similarly, the DDR tool generates the "ddr_timing.c" file.
In the comments of this file, uboot is referenced. How is this file supposed to be used ?
The help accessible from the tool does not give any answers to my questions,
Nicolas
Solved! Go to Solution.
I suggest that you can download the latest SDK from
"https://mcuxpresso.nxp.com/en/welcome"
which includes the driver and head file you need, you also can refer to the ddr tool and user guide of ddr tool as below
pls refer to the MSCALE_DDR_Tool_User_Guide.pdf
Finally found it.
Actually, there are "board.h" in several locations. Don"t know why Windows search didn't find them before.
Just to be sure, the SDK is for the Cortex-M7 only, not the Cortex-A53. Right ?
yes, just for M core
Ok.
Thanks for your support.
Hello joanxie,
There is no board.h file in the SDK archive.
Nicolas
in the "board" folder
