uboot step suggestion
2,245件の閲覧回数
sam_siu
For the u-boot step 1, I would add the following for consistence:
  1. $ export ARCH=arm64
  2. $ export CROSS_COMPILE=aarch64-linux-gnu-
I run all the steps in my build machine and it works. So I approve this version with the above modification.
2,183件の閲覧回数
yipingwang
Hello Sam Siu,
Do you mean the procedure to build u-boot?
Please refer to the following procedure
$ source /opt/fsl-qoriq/2.6/environment-setup-aarch64-fsl-linux
$ make CROSS_COMPILE=aarch64-fsl-linux- ls2088ardb_qspi_defconfig
$ make -j 4 CROSS_COMPILE=aarch64-fsl-linux- all
Yiping
