I have been building images for LS1012 OS: ubuntu 18.04 with kernel 5.4.47 using flex-builder lsdk2012 version 2.5.2012. Lately I am not able to repeat my build, I get:
fatal: unable to access 'https://source.codeaurora.org/external/qoriq/qoriq-components/linux.git/': Could not resolve host: source.codeaurora.org
Now I have upgraded to flex-builder lsdk 2108 version 2.6.2108 and try to build the 'old' system. For starters I use:
flex-builder -c linux:linux:LSDK-20.12-V5.4:custom -a arm64 -m ls1012afrwy
This seems to work. But now my question
NR 1:
how do I get the RFS for this version of ubuntu? Currently I use this command:
flex-builder -i mkrfs -m ls1012afrwy -r ubuntu:main
Been trying to find an answer in LSDKUG e.g.
4.3.7 How to build linux itb based on custom kernel and various distros
but couldn't find an answer.
and NR 2:
How do I include the linux-headers for 5.4.47? They were present in the RFS when built with the older version of flex-builder. apt doesn't help either because I cant find exactly 5.4.47 (which I need).
/usr/src/linux-headers-5.4.47
It's the nature of our project that requires this specific version of the OS.
In LSDK 20.12, please edit file configs/build_lsdk.cfg to replace “source.codeaurora.org/external/qoriq/qoriq-components” with “github.com/nxp-qoriq”, then you could use LSDK 20.12 to perform building.
1. Use the following command is correct.
2. In LSDK 21.08 build environment, please execute the following command, you will get linux-headers-*.deb in folder build/linux/kernel/arm64/LS/output.
$ flex-builder -c linux-deb -p LS
Please copy linux-headers-*.deb to the target board and execute the following command.
# dpkg -i linux-headers-*.deb
Thank you very much for your answer. After applying your suggested replacements I still had some errors involving codeaurora links, so now I have a new question:
Do I also have to replace https://source.codeaurora.org/external/imx with https://github.com/nxp-imx ?
Btw:
The list of commands I issue for building my system:
flex-builder -c linux -a arm64 -m ls1012afrwy flex-builder -i mkrfs -m ls1012afrwy -r ubuntu:main -B packages_ls1012afrwy flex-builder -c apps -m ls1012afrwy flex-builder -i merge-component -a arm64 flex-builder -i mkbootpartition -a arm64 flex-builder -i mkfw -m ls1012afrwy -b qspi
Yes, you need to replace https://source.codeaurora.org/external/imx with https://github.com/nxp-imx
