USB 3.0 micro AB acting as USB 2.0
Sarthak
I am using LS 1046ARDB board. When I am trying to connect a USB 3.0 device using USB 3.0 micro AB port on the board, it says its USB 2.0. However, it should be USB 3.0.
I want to use USB 3.0 but I am unable to do so. I tried changing the wire and also tried connecting different device compatible with USB 3.0 but USB 3.0 micro AB port says it 2.0.
I have checked the reference sheet, it says 3.0 but when I connect something its say its USB 2.0. I am using all the wires provided in the kit.
Can someone please guide me how I can change the behavior of USB 3.0 micro AB to USB 3.0.
Thanks in advance
yipingwang
Please refer to my u-boot console log, USB 3.0 device was detected successfully without any problem.
Which version LSDK are you using? Would you please provide your u-boot console log?
U-Boot 2020.04-gf46a944f71 (Dec 11 2020 - 04:34:39 +0800)
SoC: LS1046AE Rev1.0 (0x87070010)
Clock Configuration:
CPU0(A72):1800 MHz CPU1(A72):1800 MHz CPU2(A72):1800 MHz
CPU3(A72):1800 MHz
Bus: 700 MHz DDR: 2100 MT/s FMAN: 800 MHz
Reset Configuration Word (RCW):
00000000: 0e150012 10000000 00000000 00000000
00000010: 11335559 40005012 40025000 c1000000
00000020: 00000000 00000000 00000000 00238800
00000030: 20124000 00003101 00000096 00000001
Model: LS1046A RDB Board
Board: LS1046ARDB, boot from QSPI vBank 0
CPLD: V2.3
PCBA: V2.0
SERDES Reference Clocks:
SD1_CLK1 = 156.25MHZ, SD1_CLK2 = 100.00MHZ
DRAM: 7.9 GiB (DDR4, 64-bit, CL=15, ECC on)
DDR Chip-Select Interleaving Mode: CS0+CS1
SEC0: RNG instantiated
Using SERDES1 Protocol: 4403 (0x1133)
Using SERDES2 Protocol: 21849 (0x5559)
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from SPI Flash... SF: Detected s25fs512s with page size 256 Bytes, erase size 256 KiB, total 64 MiB
OK
EEPROM: NXID v1
In: serial
Out: serial
Err: serial
Net: SF: Detected s25fs512s with page size 256 Bytes, erase size 256 KiB, total 64 MiB
Fman1: Uploading microcode version 106.4.18
PCIe1: pcie@3400000 Root Complex: no link
PCIe2: pcie@3500000 Root Complex: no link
PCIe3: pcie@3600000 Root Complex: x1 gen1
e1000: 68:05:ca:35:6d:ec
FM1@DTSEC3, FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@TGEC1, FM1@TGEC2, e1000#0 [PRIME]
Hit any key to stop autoboot: 0
=> usb info
USB is stopped. Please issue 'usb start' first.
=> usb start
starting USB...
Bus usb@2f00000: Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
Bus usb@3000000: Register 200017f NbrPorts 2
USB XHCI 1.00
Bus usb@3100000: Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus usb@2f00000 for devices... 2 USB Device(s) found
scanning bus usb@3000000 for devices... 2 USB Device(s) found
scanning bus usb@3100000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 2 Storage Device(s) found
=> usb info
1: Hub, USB Revision 3.0
- U-Boot XHCI Host Controller
- Class: Hub
- PacketSize: 512 Configurations: 1
- Vendor: 0x0000 Product 0x0000 Version 1.0
Configuration: 1
- Interfaces: 1 Self Powered 0mA
Interface: 0
- Alternate Setting 0, Endpoints: 1
- Class Hub
- Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms
2: Mass Storage, USB Revision 3.0
- SanDisk Ultra USB 3.0 4C531001530430115561
- Class: (from Interface) Mass Storage
- Vendor: 0x0781 Product 0x5591 Version 1.0
Configuration: 1
- Interfaces: 1 Bus Powered 224mA
Interface: 0
- Alternate Setting 0, Endpoints: 2
- Class Mass Storage, Transp. SCSI, Bulk only
- Endpoint 1 In Bulk MaxPacket 1024
- Endpoint 2 Out Bulk MaxPacket 1024
- Class: Hub
Configuration: 1
Interface: 0
- Class Hub
- Kingston DataTraveler 3.0 60A44CB1AB9DBFA084600214
- Vendor: 0x0951 Product 0x1666 Version 1.0
Configuration: 1
Interface: 0
- Class: Hub
Configuration: 1
Interface: 0
- Class Hub
Sarthak
Thanks for quick reply
LSDK version = LSDK-21.08-0-g340b20bcb
OS = Ubuntu 20.04.5 LTS
Also I am attaching an image where it is recognizing as usb2.0
NOTICE: 16 GB DDR4, 64-bit, CL=15, ECC on, CS0+CS1
NOTICE: BL2: v2.4(release):LSDK-21.08-0-g340b20bcb
NOTICE: BL2: Built : 22:21:38, Aug 27 2021
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.4(release):LSDK-21.08-0-g340b20bcb
NOTICE: BL31: Built : 22:21:34, Aug 27 2021
NOTICE: Welcome to ls1046ardb BL31 Phase
U-Boot 2021.04-ge2eba0cd58 (Aug 27 2021 - 22:20:55 +0800)
CPU3(A72):1800 MHz
CPLD: V2.3
PCBA: V3.0
DRAM: 15.9 GiB (DDR4, 64-bit, CL=15, ECC on)
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from SPIFlash... SF: Detected s25fs512s with page size 256 B
OK
EEPROM: NXID v1
In: serial
Out: serial
Err: serial
Net: SF: Detected s25fs512s with page size 256 Bytes, erase size 256 KiB, totB
eth0: fm1-mac3, eth1: fm1-mac4, eth2: fm1-mac5, eth3: fm1-mac6, eth4: fm1-mac9,0
=> usb start
starting USB...
USB XHCI 1.00
USB XHCI 1.00
USB XHCI 1.00
=> usb info
- Class: Hub
Configuration: 1
Interface: 0
- Class Hub
2: Mass Storage, USB Revision 3.20
- USB SanDisk 3.2Gen1 0401ac76d4f76968c8cc0ae769694c6
- Vendor: 0x0781 Product 0x5581 Version 1.0
Configuration: 1
Interface: 0
- Class: Hub
Configuration: 1
Interface: 0
- Class Hub
- USB SanDisk 3.2Gen1 0901c7ea69703e26fd1a8446c2cdfd3
Configuration: 1
Interface: 0
- Class: Hub
Configuration: 1
Interface: 0
- Class Hub
yipingwang
In your u-boot log, Mass Storage devices are recognized as USB Revision 3.0, right?
