LS1046ARDB SD card image not booting
已解决
跳至解决方案
2,509 次查看
srogers
I have a new LS1046ARDB. The labels on it say:
LS1046ARDB-PB REV E
LSDK 21.08
The factory default QSPI boot works. I want to build an image for it using LSDK 21.08 flexbuild (I have been successfully building and booting images on SDCard for FRWY-LS1046A using flexbuild).
I have tried the following. In all cases the device won't boot from SDCard.
This downloads and writes an image to SDCard, but it won't boot:
./flex-installer -i auto -m ls1046ardb -d /dev/sde -p 4P=128M:2G:8G:-1
I've also tried in an lsdk 21.08 environment:
flex-builder -m ls1046ardb
flex-installer -r rootfs_lsdk2108_ubuntu_main_arm64.tgz -b boot_LS_arm64_lts_5.10.tgz -f firmware_ls1046ardb_sdboot.img -p 4P=1G:2G:2G:10G -d /dev/sde
Again this successfully builds the image and writes it to SD card, but when I flip the dip switch (SW_RCW_SRC6) it won't boot.
Can anyone please suggest what I'm missing?
标记 (2)
1 解答
2,470 次查看
srogers
This is resolved. I think my problems were caused by either:
Not using a fresh bash shell after building lsdk in a different folder, so the envs weren't right
A bad sd-card adapter
在原帖中查看解决方案
3 回复数
2,471 次查看
srogers
2,482 次查看
srogers
If I build an image using lsdk2108 the 1046ARDB does not start u-boot (no console output). I'm doing the following with a pristine flexbuild_lsdk2108_github.tgz:
flex-builder -m ls1046ardb -j16
flex-installer -b boot_LS_arm64_lts_5.10.tgz -r rootfs_lsdk2108_ubuntu_main_arm64.tgz -f firmware_ls1046ardb_sdboot.img -d /dev/sde
The same build process works for the FRWY-LS1046 using -m ls1046afrwy.
Does anyone know what the issue is?
2,489 次查看
srogers
Following the instructions here LS1046ARDB causing SD cards to become permanent 'read-only' - NXP Community the board now boots from sd card. I wonder if my partitioning options were causing the issue (these worked for FRWY-LS1046)
%3CLINGO-SUB%20id%3D%22lingo-sub-1925606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046ARDB%20SD%E5%8D%A1%E6%98%A0%E5%83%8F%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1925606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%20LS1046ARDB%E3%80%82%E4%B8%8A%E9%9D%A2%E7%9A%84%E6%A0%87%E7%AD%BE%E5%86%99%E7%9D%80%EF%BC%9A%3C%2FP%3E%3CP%3ELS1046ARDB-PB%20REV%20E%3C%2FP%3E%3CP%3ELSDK%2021.08%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8E%82%E9%BB%98%E8%AE%A4%E7%9A%84%20QSPI%20%E5%90%AF%E5%8A%A8%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%20LSDK%2021.08%20flexbuild%20%E4%B8%BA%E5%85%B6%E6%9E%84%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%9B%BE%E5%83%8F%EF%BC%88%E6%88%91%E5%B7%B2%E7%BB%8F%3CSPAN%3E%E4%BD%BF%E7%94%A8%20flexbuild%20%E6%88%90%E5%8A%9F%E5%9C%A8%20SDCard%20%E4%B8%8A%E4%B8%BA%20FRWY-LS1046A%20%E6%9E%84%E5%BB%BA%E5%92%8C%E5%90%AF%E5%8A%A8%E5%9B%BE%E5%83%8F%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%B7%B2%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%E3%80%82%E5%9C%A8%E6%89%80%E6%9C%89%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%AE%BE%E5%A4%87%E9%83%BD%E6%97%A0%E6%B3%95%E4%BB%8E%20SDCard%20%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E4%BC%9A%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%B0%86%E5%9B%BE%E5%83%8F%E5%86%99%E5%85%A5%20SDCard%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.%2Fflex-installer%20-i%20auto%20-m%20ls1046ardb%20-d%20%2Fdev%2Fsde%20-p%204P%3D128M%3A2G%3A8G%3A-1%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%B9%9F%E5%9C%A8%20lsdk%2021.08%20%E7%8E%AF%E5%A2%83%E4%B8%AD%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eflex-builder-m%20ls1046ardb%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eflex-installer%20-r%20rootfs_lsdk2108_ubuntu_main_arm64.tgz%20-b%20boot_LS_arm64_lts_5.10.tgz%20-f%20firmware_ls1046ardb_sdboot.img%20-p%204P%3D1G%3A2G%3A2G%3A10G%20-d%20%2Fdev%2Fsde%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E5%86%8D%E6%AC%A1%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%E4%BA%86%E5%9B%BE%E5%83%8F%E5%B9%B6%E5%B0%86%E5%85%B6%E5%86%99%E5%85%A5%20SD%20%E5%8D%A1%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E7%BF%BB%E8%BD%AC%20dip%20%E5%BC%80%E5%85%B3%EF%BC%88SW_RCW_SRC6%EF%BC%89%E6%97%B6%EF%BC%8C%E5%AE%83%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E6%8C%87%E5%87%BA%E6%88%91%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1926384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1046ARDB%20SD%20%E5%8D%A1%E6%98%A0%E5%83%8F%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1926384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B7%B2%E8%A7%A3%E5%86%B3%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E7%94%B1%E4%BB%A5%E4%B8%8B%E5%8E%9F%E5%9B%A0%E9%80%A0%E6%88%90%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E6%9E%84%E5%BB%BA%20lsdk%20%E5%90%8E%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E6%96%B0%E7%9A%84%20bash%20shell%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%8E%AF%E5%A2%83%E4%B8%8D%E6%AD%A3%E7%A1%AE%3C%2FP%3E%3CP%3ESD%20%E5%8D%A1%E9%80%82%E9%85%8D%E5%99%A8%E6%8D%9F%E5%9D%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1926186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1046ARDB%20SD%20%E5%8D%A1%E6%98%A0%E5%83%8F%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1926186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%20lsdk2108%20%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%EF%BC%8C1046ARDB%20%E5%B0%86%E4%B8%8D%E4%BC%9A%E5%90%AF%E5%8A%A8%20u-boot%EF%BC%88%E6%B2%A1%E6%9C%89%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BE%93%E5%87%BA%EF%BC%89%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%8E%9F%E5%A7%8B%E7%9A%84%20flexbuild_lsdk2108_github.tgz%20%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CP%3Eflex-builder-m%20ls1046ardb-j16%3C%2FP%3E%3CP%3Eflex-installer%20-b%20boot_LS_arm64_lts_5.10.tgz%20-r%20rootfs_lsdk2108_ubuntu_main_arm64.tgz%20-f%20%E5%9B%BA%E4%BB%B6_ls1046ardb_sdboot.img%20-d%20%2Fdev%2Fsde%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20-m%20ls1046afrwy%EF%BC%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E6%9E%84%E5%BB%BA%E8%BF%87%E7%A8%8B%E9%80%82%E7%94%A8%E4%BA%8E%20FRWY-LS1046%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E9%97%AE%E9%A2%98%E6%98%AF%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1926094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1046ARDB%20SD%20%E5%8D%A1%E6%98%A0%E5%83%8F%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1926094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%8C%89%E7%85%A7%E6%AD%A4%E5%A4%84%E7%9A%84%E8%AF%B4%E6%98%8E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape%2FLS1046ARDB-causing-SD-cards-to-become-permanent-read-only%2Ftd-p%2F1455332%22%20target%3D%22_blank%22%3ELS1046ARDB%20%E5%AF%BC%E8%87%B4%20SD%20%E5%8D%A1%E5%8F%98%E4%B8%BA%E6%B0%B8%E4%B9%85%E2%80%9C%E5%8F%AA%E8%AF%BB%E2%80%9D%20-%20NXP%20%E7%A4%BE%E5%8C%BA%EF%BC%8C%3C%2FA%3E%E4%B8%BB%E6%9D%BF%E7%8E%B0%E5%9C%A8%E4%BB%8E%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%88%91%E7%9A%84%E5%88%86%E5%8C%BA%E9%80%89%E9%A1%B9%E6%98%AF%E5%90%A6%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%88%E8%BF%99%E4%BA%9B%E9%80%89%E9%A1%B9%E5%AF%B9%20FRWY-LS1046%20%E6%9C%89%E6%95%88%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
