Is there any sample code available to program the Security Monitor (SecMon) that is described in the QorIQ Trust Architecture 2.1 User Guide?
解決済! 解決策の投稿を見る。
I check and in uboot we have a reference to change the secmon state. Nothing in Linux. You may use it as reference. Here is the reference.
.../u-boot/board/freescale/common/fsl_validate.c
if (its == 1)
set_sec_mon_state(HPSR_SSM_ST_SOFT_FAIL);
else
set_sec_mon_state(HPSR_SSM_ST_NON_SECURE);
Okay thank you very much!
Yes, please refer to the latest LSDK User Guide (e.g. LSDKUG_Rev21.08.pdf)
6.1.1.5 Procedure to run secure boot
and
6.1.1.5.2 Prepare board for Secure boot.
You should start reading section 6.1.1 Secure boot for all security related topics that enabled in the LSDK software for reference.
Thanks I will go through the section for secure boot.
Besides secure boot, there is a Security monitor state machine (SSM) that runs and changes states according to H/W and S/W failures. Is there any sample code available for that?
if (its == 1)
else
There is no sample code for that. The SECMON is a state machine, it change state based on signals from the HW pins/signal.
The state change diagram is in the QORIQTURST21UG, section 7.2 Security Monitor (SecMon) Figure 7-1. Security Monitor Block Diagram
If you want to manually change the state, you can touch the SecMon_HP Command Register (HPCOMR), bit 0, SSM State Transition Transition state of the system security monitor. This self-clearing bit is always read as zero. This command results only in the following transitions of the SSM:
Check State Non-Secure (when Non-Secure Boot and not in Unsecure Configuration )
Check State --> Trusted (when Secure Boot or in Unsecure Configuration ) Trusted State --> Secure Secure State --> Trusted (if not disabled by SSM_ST_DIS bit) Soft Fail --> Non-Secure (if not disabled by SSM_SFNS_DIS bit)
OR
bit 8, Software Security Violation
When set, the system security monitor treats this bit as a non-fatal security violation. This security violation has no effect on the LP section. This command results only in the following transitions of the
SSM:
Check -> Non-Secure
Trusted -> Soft Fail
Secure -> Soft Fail
