Hi:
I found that the LS1028 platform’s DDR configuration is located in the “atf/plat/nxp/soc-ls1028/ls1028ardb” directory (ddr_init.c). However, when I configure DDR with QCVS . I found that I cannot generate the ‘ddr_init.c’ file. How can I generate this file?
已解决! 转到解答。
Hello @Eddy1
The "ddr_init.c" is generated by itself once when you create the project.
From our side, we have created a new project and the "ddr_init.c" file was created by itself.
We are developing this test in Codewarrior 11.5.15. with appropriate active licenses.
Have a great day.
Hector Villarruel
Hello @Eddy1
Have a great day.
Hector Villarruel
