LSDKUG User Guide Rev. 21.08, 05 September 2022
Refers to "Set up the different chip select parameters from board header file"
Where go I get these board header file(s) for FRWY-LS1046A-AC: DEV BOARD, 64 Bit, ARM Cortex
3107056 from?
William
Solved! Go to Solution.
Hello Williawh.
Please note that you can generate the header files using the Code signing tool.
We highly recommend you to check the 6.1.1.4 Code Signing Tool section located on Layerscape Software Development Kit User Guide, Rev. 21.08, 05 September 2022.
Have a wonderful day,
Hector Villarruel
Hello Williawh.
Hector Villarruel
