We are trying to use a PCB originally created with a LS1043A CPU to bring up a LS1046A CPU. The BGA map for the LS1043A DDR pins has equivalents in the LS1046A, but there is a swap in the lanes.
Board name: LS1043 LS1046
Lane number: 0 8(ECC)
1 3
2 2
3 1
Is there a way to change the settings in the DDR component of the CodeWarrior IDE to represent the change in pinout for the 32-bit bus?
解決済! 解決策の投稿を見る。
Hello @jvfausto
Regarding your question:
Regarding your specific configuration, it is not possible, since the configurations are set to 0 to 7 , you can find the available configurations at the Codewarrior DDR component on the "DQ mapping controller pin".
Please find attached on the case an image in reference.
Have a great day.
BR,
Hector Villarruel
Hello @jvfausto
Have a great day.
BR,
Hector Villarruel
Hello @jvfausto
Hope this post finds you well,
This email is to inform you that we acknowledge the receipt of your case,
I Keep working on the solution on this case.
I’ll keep you informed on the process,
Have a great day.
