The scripts in Redlink server are interpreted by a simplified, but extended, version of the BASIC programming language.
The following is a list of the commands and statements supported by the BASIC interpreter:
GOTO 'LineNumber' IF 'relation' THEN 'statement' REPEAT : Start of a repeat block UNTIL 'relation' : End with condition of repeat block BREAKREPEATTO 'LineNumber' : Premature end of a repeat loop GOSUB 'LineNumber' RETURN TIME : Returns a 10ms incrementing count from the host
PEEK8{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' PEEK16{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' PEEK32{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' POKE8{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' 'Data' POKE16{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' 'Data' POKE32{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' 'Data' QPOKE32{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' 'Data' QSTARTTRANSFERS{[THIS] | ['ProbeIndex' 'CoreIndex']} MEMSAVE{[THIS] | ['ProbeIndex' 'CoreIndex']} 'FileName' 'Byte StartAddress' 'Length in Bytes' MEMLOAD{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Byte StartAddress' 'LengthLimit in Bytes' MEMDUMP{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Byte StartAddress' 'Length in Bytes' EXIT: Exit the server LIST: Lists the script NEW: Erases script from memory RENUMBER: Renumbers in increments of 10 LOAD 'FILENAME': Loads a script from current directory SAVE 'FILENAME': Saves a script to current directory
PROBELIST : Creates and then returns an indexed list of the probes attached PROBENUM : Returns the number of probes attached PROBEOPENBYINDEX 'ProbeIndex' : Returns a unique probe handle PROBECLOSE 'ProbeHandle' PROBECLOSEBYINDEX 'ProbeIndex' : Returns an error code PROBETIME 'ProbeIndex' : Returns time from firmware in the probe PROBESTATUS : Returns an indexed list summary of the status of the probes connected to the system PROBEVERSION 'ProbeIndex': Returns version information about probe firmware PROBEISOPEN 'ProbeIndex' PROBEHASJTAG 'ProbeIndex' PROBEHASSWD 'ProbeIndex' PROBEHASSWV 'ProbeIndex' PROBEHASETM 'ProbeIndex' PROBEDIAGNOSTICS 'ProbeIndex' : Return counts of responses from probe
CORELIST 'ProbeIndex': Returns list of TAPs/Cores found connected to specified probe CORECONFIG{[THIS] | ['ProbeIndex']}: Configures the scanchain CORESCONFIGURED 'ProbeIndex' COREREADID 'ProbeIndex' 'CoreIndex'
WIRESWDCONNECT{[THIS] | ['ProbeIndex']}: Returns the DPID WIREJTAGCONNECT{[THIS] | ['ProbeIndex']}: WIRETIMEDRESET 'ProbeIndex' 'TimeIn_ms': pulls reset and returns the end state of the wire WIREHOLDRESET 'ProbeIndex' 'State' : pulls reset and returns the end state of the wire WIRESTATUS 'ProbeIndex' : Returns the status of the wire connection on the probe specified WIRESETSPEED 'ProbeIndex' 'SpeedInHz': Requests a particular wire speed WIREGETSPEED 'ProbeIndex' : Returns the current wire speed WIRESETIDLECYCLES 'ProbeIndex' 'Cycles': Requests a specific number of idle cycles between debug transactions WIREGETIDLECYCLES 'ProbeIndex' : Returns the current number of debug idle cycles WIREISCONNECTED 'ProbeIndex' WIREGETPROTOCOL 'ProbeIndex' SELECTPROBECORE 'ProbeIndex' 'CoreIndex' : sets up for use with following commands THIS : displays the current Probe, Core pair
CMINITAPDP{[THIS] | ['ProbeIndex' 'CoreIndex']}: Initialize a CMx core ready for debug connections CMWRITEDP{[THIS] | ['ProbeIndex' 'CoreIndex']} 'REG' 'DATA': returns zero on success CMWRITEAP{[THIS] | ['ProbeIndex' 'CoreIndex']} 'REG' 'DATA': returns zero on success CMREADDP{[THIS] | ['ProbeIndex' 'CoreIndex']} 'REG': returns data CMREADAP{[THIS] | ['ProbeIndex' 'CoreIndex']} 'REG': returns data (note this deals with RDBUF on AP reads) CMCLEARERRORS{[THIS] | ['ProbeIndex' 'CoreIndex']} CMHALT{[THIS] | ['ProbeIndex' 'CoreIndex']} CMRUN{[THIS] | ['ProbeIndex' 'CoreIndex']} CMREGS{[THIS] | ['ProbeIndex' 'CoreIndex']} CMWRITEREG{[THIS] | ['ProbeIndex' 'CoreIndex']} 'RegNumber' 'Value' CMREADREG{[THIS] | ['ProbeIndex' 'CoreIndex']} 'RegNumber' CMWATCHLIST{[THIS] | ['ProbeIndex' 'CoreIndex']} CMWATCHSET{[THIS] | ['ProbeIndex' 'CoreIndex']} 'DWTIndex' 'Address' ['[RW]|R|W'] CMWATCHCLEAR{[THIS] | ['ProbeIndex' 'CoreIndex']} 'DWTIndex' CMBREAKLIST{[THIS] | ['ProbeIndex' 'CoreIndex']} : List the hardware breakpoints CMBREAKSET{[THIS] | ['ProbeIndex' 'CoreIndex']} 'Address' : Set an FPB CMBREAKCLEAR{[THIS] | ['ProbeIndex' 'CoreIndex']} ['Address'] : Clear an FPB CMSYSRESETREQ{[THIS] | ['ProbeIndex' 'CoreIndex']} : System reset request CMVECTRESETREQ{[THIS] | ['ProbeIndex' 'CoreIndex']} : Core reset request CMRESETVECTORCATCHSET{[THIS] | ['ProbeIndex' 'CoreIndex']} : Enable reset vector catch CMRESETVECTORCATCHCLEAR{[THIS] | ['ProbeIndex' 'CoreIndex']} : Disable reset vector catch
