what is "c_entry" for?
897 次查看
hosseinef
I am new to LPC MCUs programming. In an example i encountered to using of "c_entry" function in the code. Whats that for?
regards
标记 (3)
778 次查看
lpcxpresso_supp
I suspect that you are looking at some very old example code => at one point in time, various toolchains used a function called "c_entry" as their main user application code entry point, which would be called from the startup code (rather than the "main" function).
MCUXpresso IDE Support
778 次查看
soledad
Could you please mention the device and software you are using?
Sol
